AniDutta
Oct 08, 2016Apprentice
How to force a device to be connected to router and not satellite?
The main Orbi router is in my office and my media room is next to it on the second floor. I have a Chromecast that always connects to the satellite on the first floor. This results in buffering if I c...
peteytesting
Oct 08, 2016Hero
this would suggest the signal from the sat is better than the router and the system is doing the right thing , you cant really tell the client which it should connect to
- GaryInEdmondDec 06, 2016Guide
The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite. Unless you are gaming, this is probaly not a big deal. If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops. The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold. It will then connect to the satellite. I hope and pray that netgear adopts a similar approach to their router software.
- rhester72Dec 07, 2016Virtuoso
GaryInEdmond wrote:The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite. Unless you are gaming, this is probaly not a big deal. If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops. The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold. It will then connect to the satellite. I hope and pray that netgear adopts a similar approach to their router software.
Don't assume your ping will double on the satellite. My PS4 is hardwired into my satellite and I get 3ms RTT.
Rodney
- GaryInEdmondDec 07, 2016Guide
In my testing, the ping goes from an average of 10 ms when connected to the main router to 22 ms when connected to the satellite. That's not a huge difference but it's enough that I want to be able to steer my connection to the main router when I know the connection is still very good, though not as strong as the satellite. I would imagine tapping into the satellites ethernet port would reduce the ping considerably but I personally do not have that option.
