flroots
Mar 28, 2020Guide
How to force Orbi to switch to best frequency and access point?
I just purchased the RBK50 and noticed that when testing internet speed while moving from Office at one end of house to Living Room at other end, it doesn't consistently connect to the same access point (ie, Router or Satellite). To get consistent results, is there a way to force system to check and if necessary switch to optimum access point and frequency? I've used both the computer browser and app to view frequency and connected access point.
Also, is there a way to run a real time speed test on the link to a specific device?
Finally, is there a Orbi app user guide? If so, can you provide link?
Orbi User Manual: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Real time report of connection between Orbi and satellite:
- Browse to the Orbi "debug" page: http://orbilogin.net/debug
- Check the box, "Enable Telnet"
- Use a telnet client to connect to the Orbi router: i.e. telnet <ip address of Orbi>
- Type the command: satelliteinfo wifi
- This will display the Transmit and Receive rates (among other things)
Devices connected to Orbi will indeed change to the strongest signal, but it is not "instant". I find that when I have the "Attached Devices" we page open and a WiFi analysis program on my Android phone or tablet and walk briskly down the stairs from router to satellite (less briskly going upstairs), within 2 minutes I see the device change to the nearest device (and change back when I go back).
On the Orbi web interface, Advanced Tab, Advanced Setup , Wireless Setup I have enabled "Fast Roaming" (the check box at the very bottom of the page)
- flrootsGuide
Thanks a lot for the response. I have the following comments:
1. The link you provided is to the Orbi User Manual. I was asking about a manual specific to Orbi app?
2. I have tried several ways to bring up the link http://orbilogin.net/debug. Just keep getting 404 Not Found. Also, I don't see a debug option within the web interface?
3. I've enabled Fast Roaming as you suggested. It still seems very sluggish. I walked from Living Rm where Satellite is located to Office where Router is located and waited several minutes while the Orbi app was showing my phone still connected to Satellite? I had 2 network analyzer apps running in background.
Thanks again.
- flrootsGuide
CrimpOn wrote:Orbi User Manual: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
The command http://orbilogin.net/debug returns a 404 even though I have no trouble logging onto web GUI. I used the following instructions for Windows 10 to enable Telnet:
- Open “Control Panel“.
- Open “Programs“.
- Select the “Turn Windows features on or off ” option.
- Check the “Telnet Client” box.
- Click “OK“. A box will appear that says “Windows features” and “Searching for required files“. When complete, the Telnet client should be installed in Windows.
I then opened a CMD window and typed "telnet 192.168.1.1" but I got a connection failed message. I've also made sure that Remote Management was enabled in both Orbi app and web GUI (for everyone). Any hints?
- tomschmidtVirtuoso
The correct URL for the debug page is http://orbilogin.net/debug.htm (you left off the .htm)
- SW_Prodigy
flroots wrote:...
Try "Wi-Fi Sweetspots", which tests download speed in real time while you're walking around the house with your iPhone to identify the weak/dead spots. It's extermely useful when it comes to Satellite placements for optimal speed, performance, and Wi-Fi coverage.
- flrootsGuide
SW_ wrote:
flroots wrote:...
I was asking if there's a way to test in real time to a specific device not the overall speed to all devices
flroots wrote:I just purchased the RBK50 and noticed that when testing internet speed while moving from Office at one end of house to Living Room at other end, it doesn't consistently connect to the same access point (ie, Router or Satellite). To get consistent results, is there a way to force system to check and if necessary switch to optimum access point and frequency? I've used both the computer browser and app to view frequency and connected access point.
- flrootsGuide
FURRYe38 wrote:What is the size of your home? Sq Ft?
My home is just under 2000 sq ft.
What is the distance between the router and satellite(s)?It's approx. 60 feet
I should mention that I'm very happy with the coverage throughout the entire home. My issue was over the lag in Orbi's switching from one access point to the other. This is only an issue when measuring performance in each room. I simply wanted it to be optimum (not that it was unsatisfactory).
- flrootsGuide
I'm confused! I used the Orbi app to monitor the access point to which my phone was attached as I walked to a distance of over 100 ft from the side of the house in which the Satellite is located (with Router on opposite side). It never switched from Router to Satellite. This makes me wonder what the algorithm is that decides if or when to switch? Is it time-based? I would think it would frequently compare signal strengths of each access point in making the decision as to when or if to switch? I finally got it to switch by disabling WiFi, opening app which complained, and finally switching WiFi back on. Finally it switched to Satellite! Anyone have any insight into this behavior?
