flroots
Mar 28, 2020Guide
How to force Orbi to switch to best frequency and access point?
I just purchased the RBK50 and noticed that when testing internet speed while moving from Office at one end of house to Living Room at other end, it doesn't consistently connect to the same access po...
flroots
Apr 06, 2020Guide
Thanks. That made all the difference. My results are:
root@Router:/# satelliteinfo wifi [
{ "mac address" : "8C:xx:xx:xx:xx:xx",
"hop" : "1",
"bridge mac" : "8C:xx:xx:xx:xx:xx",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-60",
"backhaul macaddress" : "8C:xx:xx:xx:xx:xx",
"backhaul phytxrate" : "1300",
"backhaul phyrxrate" : "1170",
"backhaul parentmac" : "CC:xx:xx:xx:xx:xx" }
I'm supposing that the signal strength is -60 dBm and 1300 and 1170 are transmit and receive speeds, respectively. Is this correct and if so, what are the speed units?
Apr 06, 2020Guru - Experienced User
1300 and 1170 are in Mbps and these are connection rates between the RBR and RBS only.
Please edit out and don't include any MAC address information in public forum posts.
flroots wrote:Thanks. That made all the difference. My results are:
- flrootsApr 06, 2020Guide
Thanks for the info. I can't figure out how to edit my prior post.
- FURRYe38Apr 06, 2020Guru - Experienced User
Please send a forum post to Blanca_O and Christian_R and ask them to delete that information from the post. :smileywink:
Please delete mac addresses
