SunriseMan
Aug 30, 2020Guide
How to get Orbi to pass through DNS information in DHCP?
I have an Orbi RBR50 running Firmware Version V2.5.1.16. I'm using its DHCP feature. The problem is that no matter what settings I try in the configuration, it always hands out client leases with the...
Aug 30, 2020Guru - Experienced User
Most of NG routers don't allow for DNS proxy bypass. So you can set DNS on the router for any kind of DNS you want to use, however all clients will only get the routers IP address for there DNS entries.
