Retired_Member
Apr 15, 2018How to get the best cverage? AP mode?
Hi Everyone, Looking for some help in regards to my Orbi. I have a four story condo townhouse. Currently I only have an Orbi Router and one Orbi Satellite. The router is placed on the main level,...
st_shaw
Apr 15, 2018Master
It is very difficult to achieve coverage vertically across many floors. Your best coverage would be achieved with a couple wireless access points on each floor, but that requires that you have Ethernet wiring in place on each floor.
When you have two or more satellites, Orbi supports "daisy chain" topology, where a satellite connects through the nearest satellite instead of directly to the router. You might have better results with this topology and additional satellites. However, the Orbis decide on their own whether to connect using daisy chain and you have no control over it.
Retired_Member
Apr 15, 2018Thanks for the advice. I think I will try the plug in orbi satellite for the second floor and see what kind of results I get. Worst case scenario I return it.
