armoredsaint
Oct 17, 2017Apprentice
How to hide my SSID?
I know you can hide the Guest SSID, but what about the main wifi SSID? I can't find it also the guest ssid when you de-select, it hangs also...another glitchy netgear software
DarrenM
Oct 19, 2017Sr. NETGEAR Moderator
Click Advanced-Advanced Setup-Wireless settings there you can un check broadcast the SSID of each band.
DarrenM
moutainraven
Oct 29, 2017Aspirant
I do not see the option to hide main SSID in Advanced Wireless Settings. Only have option to hide Guest's
- st_shawOct 29, 2017Master
Unless you have old firmware or something, it's there. Read Darren's instructions carefully and look again.
