armoredsaint
Oct 17, 2017Apprentice
How to hide my SSID?
I know you can hide the Guest SSID, but what about the main wifi SSID? I can't find it also the guest ssid when you de-select, it hangs also...another glitchy netgear software
moutainraven
Oct 29, 2017Aspirant
I do not see the option to hide main SSID in Advanced Wireless Settings. Only have option to hide Guest's
st_shaw
Oct 29, 2017Master
Unless you have old firmware or something, it's there. Read Darren's instructions carefully and look again.
