Vanasse
Jun 09, 2021Aspirant
How to increase wifi speed (130 mbs fed to router but 39 mbs max wifi )
Hello, I have upgraded my Internet provider to a 120 mbs feed into my home. I am actually getting 130 mbs at the RBR50 Orbi router. However, the wifi speed in my home reaches only 39 mbs. How can...
Jun 09, 2021Guru - Experienced User
Be sure both RBR and RBS are using same version of FW.
What wireless devices are you using to speed test with? Be sure the device is connected to the RBR or RBS for testing. Turn OFF the RBS temporarily.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
