magedsabri
May 02, 2020Tutor
How to manually control backhaul connection ORBAC2200
How can I manually control the backhaul connection between satellites and router, when they connect automatically I suffer from dropouts very often because satellites keeps on changing backhaul connec...
CrimpOn
May 02, 2020Guru - Experienced User
This isn't enough information to offer advice. How many satellites total? Normally, once they configure themselves, they stay that way.
The ONLY way to "guarantee" how an Orbi network is configured is to run ethernet cables. (A task that most of us find impractical.)
magedsabri
May 03, 2020Tutor
CrimpOn wrote:This isn't enough information to offer advice. How many satellites total?
- I have 2 satellites and 1 Orbi Voice satellite, they are 30 feet or a little bit more from each other.
Not the case with me at all, they change frequently and router itself is restarting multiple times a day randomly.
This is not an option for me, my 2 floors home is not wired.
- FURRYe38May 03, 2020Guru - Experienced User
Users can't control the wireless backhaul, its not user configurable.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
