PSone
Apr 22, 2020Tutor
How to manually update RBS50 firmware without orbilogin.com
I have an Orbi Router RBR40 (firmware V2.3.5.32) with 2 satellite RBW30 (firmware V2.3.5.6), and I bought RBS50 and I want to add it as a new satellite, but I have never been able to successfully add...
PSone
Apr 22, 2020Tutor
Hi FURRYe38
Thanks for fast advised, and I have done what you are saying, but when I reset and had wait untul 2 minutes, and never get amber, instead it has slowly white flashing.
Then I tried to connect RBS50 to PC and found the IP address is 169.254.41.210, when I type on the browser, it says "Site can't be reached"
Can you suggest other method?
Thanks.
Apr 22, 2020Guru - Experienced User
Did you wait a full 5 minutes before checking the IP address status on the PC? DHCP on the RBS doesn't enable till about 5 minutes in after you reset the RBS by pressing the back reset button for 15 seconds then release.
- PSoneApr 22, 2020Tutor
Yes, I have wait around 5 min, and the IP address has found on the network, on systems pref on macos.
When I press the reset button around 10-15 second, the LED turn flashing RED, after I released, the LED turn solid Green.
This RBS50 is never connected from the beginning I bought, I bought this item on ebay, I dont think the RBS50 is working when I got it.
If you have any other suggestion, please advise.
- FURRYe38Apr 22, 2020Guru - Experienced User
Ya if you don't see a 192.168.1.something address on your PCs LAN adapter when directly connected to the RBS after the reset and waiting 5 minutes, then the RBS is bad.
Not sure if this method will work to try to recover it or not:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
If this all fails, I would return the unit to the seller if possible.
Thanks for the advise, I will try to update firmware via TFTP client.
Will update the progress.
Thanks, its late at night here.
My problem is exactly the same with these guys, please see attached.
