PSone
Apr 22, 2020Tutor
How to manually update RBS50 firmware without orbilogin.com
I have an Orbi Router RBR40 (firmware V2.3.5.32) with 2 satellite RBW30 (firmware V2.3.5.6), and I bought RBS50 and I want to add it as a new satellite, but I have never been able to successfully add...
Apr 22, 2020Guru - Experienced User
Ya if you don't see a 192.168.1.something address on your PCs LAN adapter when directly connected to the RBS after the reset and waiting 5 minutes, then the RBS is bad.
Not sure if this method will work to try to recover it or not:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
If this all fails, I would return the unit to the seller if possible.
PSone
Apr 22, 2020Tutor
Thanks for the advise, I will try to update firmware via TFTP client.
Will update the progress.
Thanks, its late at night here.
- FURRYe38Apr 22, 2020Guru - Experienced User
:smileywink:
- PSoneApr 23, 2020Tutor
Hi, I've try to update via FTP, but no luck, the RBS50 dont have any IP address, so I couldnt update even via FTP or direct connect from PC to RBS50, and I assume the unit was defect.
Thank you so much for your advise, if the unit is working, your two advised should work.
Once again, thank you so much.
- FURRYe38Apr 23, 2020Guru - Experienced User
Ya seems like the RBS is just bad. Send it back and try another RBS.
Good Luck.
