RikParr73
Aug 31, 2018Aspirant
How to open RTSP 554 on Orbi?
Hi
Trying to set up cloud storage for my CCTV, can't see option for port forwading in advanced settings for RTSP 554, am I looking in the wrong place? Searched around and can't see where.
Aug 31, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the NG router is connected too?
There may not be a preset for that port. Have you tried a manual configuration for Port Forwarding?
Besure to disable uPnP if you set up a Manual Port Forward configuration...
RikParr73
Modem is a Virgin Media Superhub 2 (UK) I have tried manual port forward set up on RBR50. uPnP is disabled on Orbi. Superhub 2 is set to Modem and Orbi as router. For some reason unable to access modem GUI.
