RikParr73
Dec 23, 2020Aspirant
How to optimize my Orbi Network/Am I getting the best performance?
Hi My network is detailed in the attached diagram, hope it makes sense. I'm not convinced I am getting the full potential from my system, probably because of poor configuration (by me) on the Orb...
Dec 23, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- RikParr73Dec 24, 2020Aspirant
Thanks for your reply. The wireless Sat is less than 30ft from the RBR50. I will check the links you have kindly provided to see if I can improve things.
- FURRYe38Dec 24, 2020Guru - Experienced User
IF the RBS is less that 30 feet, thats too close. You'll need to move the RBS farther away from the RBR.
