ignoic
Nov 09, 2024Aspirant
How to pair an rbk30 to existing system??
We use rbr50 2unit system at our place and I found this unit at a plug-in at ourlocal pawnshop Is there a way to pair it to our system as an extra extender?
Nov 09, 2024Guru - Experienced User
The RBK is the whole kit. If you got the kid, you can use the satellites and add to the 50 series.
If its just a router, you could just it in access point mode hardwired in
- CrimpOnNov 09, 2024Guru - Experienced User
or, if it is only the RBW30 (wall-plug) satellite, then it can be added to the RBRR50 system as a satellite.
