Frankp2112
Apr 15, 2022Aspirant
How to Prevent auto firmware update
Hi, Is there a way of disabling automatic firmware updates. I have an Orbi RBR50v2 Thanks Frank
CrimpOn
Apr 15, 2022Guru - Experienced User
Yes, there is. Is there a specific reason why?
- Frankp2112Apr 15, 2022Aspirant
Beciasue the last update caused me so many issues I had to revert to an earlier version - So I would prefer to be in control of this. I wont wake up to what appears to be a shoddily tested piece of code being automatically updated on my router which causes it to drop and run so slowly -I thought I was on a dial up line.
Can you tell me how to revent the firmware from being upgraded?
Thanks
Frank.
- CrimpOnApr 16, 2022Guru - Experienced User
Please check your InBox for a private message. (upper right corner of the screen)
