Retired_Member
Jul 27, 2018How to properly reboot Orbi RBR20 with 2 satellites
I have an RBW20 unit with 2 RBW30 units, and I'm curious the proper way to reboot the system, so my devices hit the closest beacon. Currently my Orbi wifi drops out when moving from room to room, an...
waynealight
Jul 28, 2018Apprentice
on my setup i have fast roaming enabled. after i get the system fully booted all the devices will slowly switch to the best connection. usually happens within a day for stuff like thermostats and smart devices. things like computers and phones will switch sooner. but turning off and on wifi will force the reconnect.
Retired_Member
Jul 28, 2018I purchased the whole system to provide better coverage around the house, and now it's like having cell towers. you can drop a connection between 2 rooms. wifi devices attach to the main router even if it's further distance away than a satellite causing poor performance. I continue to have no coverage in my garage, even though a satellite unit is on the wall next to the garage. I feel the system would work better as a standalone router, but it's not worth it.
- waynealightJul 28, 2018Apprentice
if you are able to return i would. then upgrade to a rbk40 or 50 system. I have the rbk50. so one router and one satellite. 3k sqft. router upstairs, satellite down stairs, full strength anywhere in the house, garage and anywhere on my 1/4 acre property. I would add an outdoor unit if i had more land.
