taohat
Jun 07, 2018Star
how to remove an inactive orbi system from orbi app
I am using orbi app version 2.2 on ios. For remote management, two orbi systems are showing up. One was an inactive one that was already returned a while ago. How can it be removed?
- Jan 18, 2019I updated my Orbi app (IOS) today to a new SW (2.2.10.6). In this new software it's possible to remove a system from the list of products. Please try that. Thank you Netgear!
Jun 12, 2018Guru - Experienced User
You might want to phone contact NG support and ask for help and information regarding this...
Emperor1
Jun 17, 2018Guide
Have you find a solution for that ?
I'm in the same boat ...
I remove my old unused Orbi system from my Netgear web site but it continues to be shown in my iPhone App in remote managment section ...
Any help ?
- taohatJun 18, 2018Star
Any help ?
It was NOT resolved. Very disappointed with netgear support.
Exactly as you described, even after I deregistered the old orbi from mynetgear, the zombie system still shows up in orbi app under remote management. And there was no way to delete it from the app.
I opened a case with netgear support. No response. I PMed DarrenM here. No response. I called netgear support. Was on the phone for over 1 hour. The lady saw my old system on her end. But she kept lecturing me how removing it from my account would not help. I got so tired of convincing her and just said can you delete it from my account whether it would help me or not. Then she said she would have to escalate this since "it has to do with data security". What a BS! I was asking to give up access to something, not request access. She promised to call me back the next day. This was a week ago. But she never did.
I cannot understand this. How hard is it to update the app to give customer the option to remove a disconnected or offline orbi?
- Emperor1Jun 18, 2018Guide
The odd is that now i cannot access anymore to my new active Orbi system through remote managment ... it's always shown in remote managment section as 'disconnected' .... both with my old unused removed Orbi system ... i'm extremely disappointed ... can you see your new Orbi system through remote managment ?
- taohatJun 19, 2018Star
I can see the new system in orbi app, under remote management. You may try restarting the app by swiping it away and re-opening. But the old system is also showing up there in my account. There should really be a simple way to remove an old system from the account. If the old system finds a new owner, I would not want to still have access to it.
