taohat
Jun 07, 2018Star
how to remove an inactive orbi system from orbi app
I am using orbi app version 2.2 on ios. For remote management, two orbi systems are showing up. One was an inactive one that was already returned a while ago. How can it be removed?
- Jan 18, 2019I updated my Orbi app (IOS) today to a new SW (2.2.10.6). In this new software it's possible to remove a system from the list of products. Please try that. Thank you Netgear!
jagsny
Oct 12, 2018Tutor
Its simple. Go to orbilogin.com
and username admin/ password-the one you set up.
Click on devices and remove the ones you want.
- Emperor1Oct 13, 2018Guide
It simply not works ... when i click on my old unused Orbi System the iPhone App says Device offline and cannot remove it ... when Devs will resolve that issue ?
- FURRYe38Oct 13, 2018Guru - Experienced User
- jagsnyOct 13, 2018Tutor
You need to be connected to orbi wifi on your iphone. or use your mac/pc..connected to your orbi network.
goto orbilogin.com or 192.168.1.1
you should see a login window. You will see a box that says "attached devices". Click on that and look for inactive devices you want to remove.
