taohat
Jun 07, 2018Star
how to remove an inactive orbi system from orbi app
I am using orbi app version 2.2 on ios. For remote management, two orbi systems are showing up. One was an inactive one that was already returned a while ago. How can it be removed?
- Jan 18, 2019I updated my Orbi app (IOS) today to a new SW (2.2.10.6). In this new software it's possible to remove a system from the list of products. Please try that. Thank you Netgear!
jagsny
Oct 14, 2018Tutor
I returned one orbi system and it was still showing in my orbi app as inactive locally or remotely. YOU CAN NOT REMOVE IT FROM THE ORBI APP. You need to login into router by first making sure you are connected to your new Orbi sysytem and then going to 192.168.1.1 OR orbilogin.com and then you will see the whole system : Router and Satellites there including that you no longer have. Click REMOVE on the ones you want to remove.
After that go to your orbi app and refresh. Old system will be gone. Try locally or Remotely. Worked for me.
Blanca_O
Oct 14, 2018NETGEAR Employee Retired
I have sent you a message. Please check your inbox.
Blanca
Community Team
- AnseltmchsDec 02, 2018AspirantHas this issue been resolved? I'm having the same issue
- Emperor1Dec 02, 2018GuideNo the bug it's still here!
- Pakman626Dec 09, 2018Tutor
Having the same issue. An Orbi router I returned is still showing up in the Orbi app under "Your Products." Although it is red dot and disconnected. How do I remove this?
- Emperor1Dec 09, 2018Guide
it's impossible ... i've given also some months ago my inactive serial to Netgear support to fix that issue but nothing happens ... disapponted ....
- gonickerJan 13, 2019InitiateWhy can’t you just post how to do it? Why do you moderators keep messaging people and saying contact customer service.... WE TRIED THAT ALREADY!! Fix the issue. If there is no fix then say that. Post on this thread what the solution is.
- Emperor1Jan 13, 2019Guide
no solution till today
i've also in private as asked give the serial number of the old unused Orbi System months ago ... still issue, as said ...
