taohat
Jun 07, 2018Star
how to remove an inactive orbi system from orbi app
I am using orbi app version 2.2 on ios. For remote management, two orbi systems are showing up. One was an inactive one that was already returned a while ago. How can it be removed?
- Jan 18, 2019I updated my Orbi app (IOS) today to a new SW (2.2.10.6). In this new software it's possible to remove a system from the list of products. Please try that. Thank you Netgear!
nlaughter
Jan 18, 2019Initiate
Hey Netgear,
I'm a professional software engineer and can fix this issue for you within a few hours. Since it's something that benefits me personally, I'd be willing to do it for free. Just let me know. I guess we'll see what your commitment to customer service looks like when someone is literally willing to hand you hundreds of dollars in software to fix a major oversight in your app.
Jan 18, 2019Guru - Experienced User
You can file a support ticked here:
https://www.netgear.com/mynetgear/registration/login.aspx
nlaughter wrote:
Hey Netgear,
- nlaughterJan 18, 2019Initiate
My point is that this isn't something that should require a support ticket. This is an easy fix to enable the user to manage their account from the mobile app that you guys just...didn't do.
- Pakman626Jan 18, 2019Tutor
Exactly...thank you.
- FURRYe38Jan 18, 2019Guru - Experienced User
Something you can notify them about by creating a support ticket. Nothing can be done here in the forums.
- ekhalilJan 18, 2019MasterI updated my Orbi app (IOS) today to a new SW (2.2.10.6). In this new software it's possible to remove a system from the list of products. Please try that. Thank you Netgear!
