Muhrofi5
Jun 29, 2022Aspirant
How to remove securty account on orbi
I buy second orbi and the seller has removed the orbi router device from his account, but when I click on the security app it still uses the verification code from the seller's account
Muhrofi5
Not work
KevinLiT
Jun 29, 2022NETGEAR Moderator
Hello Muhrofi5 ,
Welcome to the NETGEAR Community!
I understand that you purchased an Orbi second hand and the security features are still using the seller's information.
Please inform the seller that he/she will need to do the following:
For NETGEAR Armor:
- From the Armor portal dashboard navigate to:
- Select all devices
- Select the three dots
- Select the device that needs to be removed
- Select Remove
To unregister the NETGEAR product from their NETGEAR account:
- Visit my.netgear.com.
- Enter your Email Address and Password.
- Click or tap NETGEAR Sign In.
- Select Products > My Registered Products.
- Select a product to unregister from your account.
- Scroll down and click or tap the grey UNREGISTER PRODUCT bar.
Confirmation options display.
- Click or tap YES, UNREGISTER MY PRODUCT.
Your product is unregistered.
Return to the My Registered Products page and confirm that the product is removed from your account.
Best,
Kevin
Community Team
