wifey7700
Sep 27, 2021Aspirant
How to separate 5 ghz 2.4 ghz on my Orbi RBR850 Router and 2 satellites?
Was informed that I need to separate the orbi network (due to cameras hooked up to the Internet). The cameras will only operate on the 2.4 ghz and was told to to separate the 5.0 ghz and the 2.4 ghz...
Sep 28, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Can someone give me information as to how I can do this?
Thanks in advance.
