WorkingMan
Sep 18, 2021Aspirant
How to separate SSID's? No telnet after upgrade.
There is no Telnet checkbox any more. What is the procedure to separate SSID's? I need to connect my smart light. Thanks!
Sep 19, 2021Guru - Experienced User
there isn't a procedure to seperate them anymore. Netgear pulled telnet access and even disabled the option of disabling auto-updates so people could downgrade to keep telnet.
but like CrimpOn says, usually you can get IoT devices working. Takes a little playing around sometimes to get your device on 2.4ghz (lazy coding on the IoT device makers part to require that).
- kelfDec 29, 2021Tutor
Hopefully NG will add separate SSID soon... I see 6E has the feature. Unless they wanna force everyone to buy 6E :smileymad:
Separate SSID for IoT: A separate network name for your Internet of things (IoT) devices like smart lights, smart plugs, and smart speakers, means it is easier to connect those devices that prefer a dedicated 2.4 GHz connection.
- FURRYe38Dec 29, 2021Guru - Experienced User
6E only has a separate radio for IoT devices. Otherwise the main WiFi radios are still a single SSID which can't be separated.
If you want some SSID separation on 50 series Orbi, you could load up Voxels FW which I believe still supports some SSID separation:
