shankara
Apr 28, 2021Tutor
How to set up Orbi with optical fiber connection?
Hello: We have been happily using the Netgear Orbi RBR50 router with one satellite in our home here in India. But we have just got a new broadband connection for which we are having trouble setting u...
CrimpOn
Apr 28, 2021Guru - Experienced User
Orbi must be connected with an ethernet cable. If the ISP's router has an optical port that connects to the actual fiber, then the only option is to connect the Orbi to that ISP device. (My son has similar service in North Carolina.) Yes, it would be be better to disable any WiFi feature on the ISP device.
(It would be even more desirable to disable any "routing" features as well.)
Good Luck
