Kopol
Jan 25, 2019Aspirant
How to set up wired back haul?
Hi,
I just purchased RBK50 today. I have successfully set it up with wireless backhaul in ACCESS POINT mode.
I have not been able to set up wired backhaul. Once I connect the LAN wire to the satell...
ekhalil
Jan 25, 2019Master
Since you already have a wireless backhaul, the backhaul should change to wired once you connect the cables.
It seems that the Cisco router is doing something that affects this. Is it possible to connect them directly or through a simple switch to test?
