Kopol
Jan 25, 2019Aspirant
How to set up wired back haul?
Hi,
I just purchased RBK50 today. I have successfully set it up with wireless backhaul in ACCESS POINT mode.
I have not been able to set up wired backhaul. Once I connect the LAN wire to the satell...
Jan 26, 2019Guru - Experienced User
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
Kopol wrote:
Hi, I just purchased RBK50 today. I have successfully set it up with wireless backhaul in ACCESS POINT mode. I have not been able to set up wired backhaul. Once I connect the LAN wire to the satellite disappears from the connected satellite list. What is the procedure to do this? Incidentally, the main and satellite are connected to my Cisco RV345 router. Thank you,
