1tnt55
Jun 15, 2022Aspirant
How to setup Orbi satellites?
Hello 1tnt55,
Welcome to the NETGEAR Community!!!!
I understand that you would like a tutorial on how to set up your Orbi satellites.
Please navigate to the link below for a video tutorial:
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-WiFi-System
Best,
Kevin
Community Team
- KevinLiTNETGEAR Moderator
Hello 1tnt55,
Best,
Kevin
Community Team
- 1tnt55AspirantDear Kevin
Thanks for the tutorial. Now that I discovered the power cables in the almost invisible bottom hiding place in the box, I will use the tutorial tomorrow and hope I can use the Orbit items. Tnt55- KevinLiTNETGEAR Moderator
Hi 1tnt55,
Awesome, I am happy you found the power cable.
Be sure to let me know if you have any additional questions.
Best,
Kevin
Community Team
- 1tnt55AspirantThere are no wires (nothing with electrical prongs and "thingy" to plug into the actual satellite port) included with the router and satellites. I LITERALLY can't plug them into wall outlets. Why don't they tell you to purchase one per satellite?!!
lectricl- KevinLiTNETGEAR Moderator
Hi 1tnt55,
The power adapter comes with the satellite. Check for a small white box in your packaging.
Please see the video below for items that should be included with your system:
https://www.youtube.com/watch?v=QsRd-R47ITs
Best,
Kevin
Community Team
