Pratyay6
May 31, 2017Follower
How to setup Orbi system with existing routers
I have an existing home network with 4 routers, two netgear AC750s and two from another manufacturer. I have them connected with one AC750 as the master with DHCP turned on, and the others connected ...
- Jun 01, 2017
Hello Pratyay6
All you would need to do is plug orbi into one of the routers and then enable AP mode.
DarrenM
DarrenM
Jun 01, 2017Sr. NETGEAR Moderator
Hello Pratyay6
DarrenM
TraptPatriot
Jun 01, 2017Aspirant
Hi Darren,
Would putting the Orbi in AP mode disable the DHCP or any other routing functions on the Orbi? Thanks!
Dan
