Pratyay6's avatar
Pratyay6
Follower
May 31, 2017
How to setup Orbi system with existing routers
I have an existing home network with 4 routers, two netgear AC750s and two from another manufacturer. I have them connected with one AC750 as the master with DHCP turned on, and the others connected ...
  • DarrenM's avatar
    Jun 01, 2017
    Hello Pratyay6
    All you would need to do is plug orbi into one of the routers and then enable AP mode.
    DarrenM
