helipaddy
Apr 13, 2020Follower
How to switch the outdoor Orbi RBS50Y back to being a satellite instead of an extender
I have tried doing a reset. That ends up providing me with the NETGEAREXT wifi which, if I login to mywifiext.local, shows the RBS50Y in extender mode with no way to switch it back to normal. I hav...
Apr 13, 2020Guru - Experienced User
You have to download and apply the "Orbi Mode" FW to the RBSY while it's connected. Factory reset then set it up as a satellite.
