Dream_Designer
Apr 20, 2021Aspirant
How to Sync/connect 4th Satellite to Orbi RBR50
I know as per manual you can connect only 3 satellites, But aftre buying 4th Staellite negear customer support was helping around, due to lockdown my support time expired now i am stuck with 4th sate...
Dream_Designer
Yes FW is same now, during support fron netgear they help me download the FW, now please elebaorate how to proceed to next step of connecting 4th staellite, I am not a techie, is there any guide i can follor or a you tube tutorial?
Dream_Designer
This is geranl 3 satellite guide whereas for 4th satellite there is another way around, this does not work
- FURRYe38Apr 20, 2021Guru - Experienced User
Try turning OFF all of the other RBS and see if you can sync the 4th with the RBR alone.
Is Daisy Chain enabled? You might disable this on the RBR first.
Dream_Designer wrote:This is geranl 3 satellite guide whereas for 4th satellite there is another way around, this does not work
- Dream_DesignerApr 20, 2021Aspirant
I Tried this last time one of the staellite stops working, so technically it allows only 3
now i have disbales the daisy chain let me try if it works
