sandman512's avatar
sandman512
Apprentice
Feb 10, 2020
How to tell if satellite is hard wired?
So, quick question.  I just hooked up my ORBI mesh system and I am able to hard wire each of the satellites.  While I plugged it in, is there a way to check that the system is up and running correctl...
  • sandman512's avatar
    sandman512
    Feb 11, 2020
    So, picked up a new cat5 cable this morning.  Follwoed the picture in the manual and BINGO, all hard wired up.  Thank you!
