sandman512
Feb 10, 2020Apprentice
How to tell if satellite is hard wired?
So, quick question. I just hooked up my ORBI mesh system and I am able to hard wire each of the satellites. While I plugged it in, is there a way to check that the system is up and running correctl...
- Feb 11, 2020
So, picked up a new cat5 cable this morning. Follwoed the picture in the manual and BINGO, all hard wired up. Thank you!
sandman512
Thanks for the reply. They are dotted, BUT i just wired them via cable.
Feb 10, 2020Guru - Experienced User
Are they directly connected to the RBR or running thru a LAN network switch?
sandman512 wrote:Thanks for the reply. They are dotted, BUT i just wired them via cable.
- sandman512Feb 10, 2020Apprentice
So, the RBR is to a switch and from there to the satellite. On that first satellite I conencted my SONOS system and that succesfullly created it's own SONOS NET.
CORRECTION: I wired a cable directly from the router to a satellite.
- FURRYe38Feb 10, 2020Guru - Experienced User
RBS need to be connected directly to the RBR or via a non managed non green ethernet Gb LAN switch.
RBS can't be connected to any other device.
SO both are connected directly to the RBR or is there a switch in between one of the RBS an RBR?
