sandman512
Feb 10, 2020Apprentice
How to tell if satellite is hard wired?
So, quick question. I just hooked up my ORBI mesh system and I am able to hard wire each of the satellites. While I plugged it in, is there a way to check that the system is up and running correctl...
- Feb 11, 2020
So, picked up a new cat5 cable this morning. Follwoed the picture in the manual and BINGO, all hard wired up. Thank you!
Feb 10, 2020Guru - Experienced User
SO both are connected directly to the RBR or is there a switch in between one of the RBS an RBR?
sandman512
So, after doing some trouble shooting, I found that the cable from the Router to the first satellite was no good. I swapped out wires and the first satellite is hard wired; confirmed via the app. I than ran a wire from the first satellite to the second, confirmed that wire was good, BUT it does not show up as hard wired.
- FURRYe38Feb 10, 2020Guru - Experienced User
You might factory reset, then power OFF the RBS, remove it from the RBRs web page, then turn ON RBS and resync it. Try this while in same room with the RBR.
- sandman512Feb 10, 2020Apprentice
Once again, thank you for the assistance. So, looking at the link you posted, one thing I noticed is that I do not have my wires configured as they are depicted in the picture(daisy chain).
Yes. so Each RBS is directly connected to the back of the RBR right?
So, I have a wire from the router to the satellite #1 and a wire from #1 to #2. The wires are just plugged into the back, BUT NOT in the positions shown in the pictures. FWIW, I tested the wire that goes to #2 and it was working(hooked up to my mac and was getting internet.)
And daisy chain is disabled on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
What happens if you directly connect #2 to RBR?
Unfortunately, I had to leave for work. When I get home, I am going to redo the wires as in the pics. I will post back here with the results.
- FURRYe38Feb 11, 2020Guru - Experienced User
:smileywink:
- sandman512Feb 11, 2020Apprentice
Hope the CAT5 was a CAT5e. CAT5 is older and doesn't offer great performances. CAT6 is highly recommended.
However glad the new cable worked. Seemed like you had a bad cable in the mix.
Please mark your post thread and solved so other will know.
Enjoy. :smileywink:
