sandman512
Feb 10, 2020Apprentice
How to tell if satellite is hard wired?
So, quick question. I just hooked up my ORBI mesh system and I am able to hard wire each of the satellites. While I plugged it in, is there a way to check that the system is up and running correctl...
- Feb 11, 2020
So, picked up a new cat5 cable this morning. Follwoed the picture in the manual and BINGO, all hard wired up. Thank you!
sandman512
So, I have a wire from the router to the satellite #1 and a wire from #1 to #2. The wires are just plugged into the back, BUT NOT in the positions shown in the pictures. FWIW, I tested the wire that goes to #2 and it was working(hooked up to my mac and was getting internet.)
Feb 10, 2020Guru - Experienced User
And daisy chain is disabled on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
What happens if you directly connect #2 to RBR?
- sandman512Feb 10, 2020Apprentice
Unfortunately, I had to leave for work. When I get home, I am going to redo the wires as in the pics. I will post back here with the results.
- FURRYe38Feb 11, 2020Guru - Experienced User
:smileywink:
- sandman512Feb 11, 2020Apprentice
Hope the CAT5 was a CAT5e. CAT5 is older and doesn't offer great performances. CAT6 is highly recommended.
However glad the new cable worked. Seemed like you had a bad cable in the mix.
Please mark your post thread and solved so other will know.
Enjoy. :smileywink:
