sandman512
Feb 10, 2020Apprentice
How to tell if satellite is hard wired?
So, quick question. I just hooked up my ORBI mesh system and I am able to hard wire each of the satellites. While I plugged it in, is there a way to check that the system is up and running correctl...
- Feb 11, 2020
So, picked up a new cat5 cable this morning. Follwoed the picture in the manual and BINGO, all hard wired up. Thank you!
Feb 11, 2020Guru - Experienced User
:smileywink:
sandman512
Feb 11, 2020Apprentice
- FURRYe38Feb 11, 2020Guru - Experienced User
Hope the CAT5 was a CAT5e. CAT5 is older and doesn't offer great performances. CAT6 is highly recommended.
However glad the new cable worked. Seemed like you had a bad cable in the mix.
Please mark your post thread and solved so other will know.
Enjoy. :smileywink:
