alokeprasad
Apr 15, 2021Mentor
How to tell which satellite a device is connected to? How to make it switch satellites?
Q1. How can I tell from the web interface which satellite a device is connected to?
I can use the iOS app to do so, but it seems to be a glating oversight to not have this info be available via the web interface.
Q2. How/when does the Orbi decide to switch connections to the strongest one? I have brought my Ring camera from outdoors to the same room (within 3 ft of the RBR), but it still shows connected to the satellite it used to connect to when it was outside. The signal strength is low (according to the Ring app), as it should be because it is now much farthar away from the RBS it is still connected to, all the while being within spitting distance from teh RBR!
Q3. How do I make it switch to the RBR? I could restart the camera, but that is a kludgy way to do that. Any better way? Shouldn't the "mesh" design of the Orbi do that?
Note: "Enable fast roaming" is disabled in Advanced ->Advanced Wireless Settings. This is a common advice here.
Besides, it has been 6 hours! even "slow roaming" should have worked by now.
Aloke
Fast Roaming is IEEE standard 802.11r. https://en.wikipedia.org/wiki/IEEE_802.11r-2008
Notice in the first sentence, "for devices in motion". It is common for the network software in smartphone, tablets, and laptops to be set up to "roam" (either the 'old way' or 802.11r). Devices that do not move seem to be programmed to connect to an access point and stay connected until the access point signal goes away entirely.
A Ring battery camera is not likely to "roam" because it is physically moved to a new location.
As you have discovered, unless a device is programmed to look for better WiFi connections, there are only three methods that will get it to change:
- Power Cycle the device.
- Have the device "forget" the WiFi, search again, and reconnect. (which can be done on a television, but not on a security camera because once it disconnects it no longer accepts commands)
- Power Cycle the access point.
I doubt very much a complaint will get much traction at Ring. Generally, security cameras are placed somewhere and left there for extended periods of time.
Sorry if I missed the point of the discussion.
alokeprasad wrote:Q1. How can I tell from the web interface which satellite a device is connected to?
Either check the RBS web page or use the Orbi app and switch to the RBS in Network Map to see whats connected at the RBS.
Client devices pick and choose what signal they connect to.
Placement and distance from either RBR or RBS will be key.
FR should be enabled.
- alokeprasadMentor
The Attached devices on the RBR's web interface does not list the satellite for some devices. See attached screebshot. My satellites are named "up" and "down". Those devices are giving me some problems..
How does a _device_ select which (satellite or router) to connect to? RThe device would be recieving and broadcasting on a particular channel/frequency. Isn't it up to the Orbi system to beamform and send the appropriate packets to the device to/from the nearest satellite?
The suspect device is 3 feet from the RBR and 40 feet from the satellite it is still connected to. This switching to the nearest device is not happening correctly.
Who do I blame? How do I correct it?
I'll togge that. Maybe that will fix the "wrong satellite" problem.
I see GUEST in the status page do you have Guest Network enabled?
All that happens on the devices wifi drivers and algorithm done by the devices Mfr. in accordance to wifi specs
RThe device would be recieving and broadcasting on a particular channel/frequency. Isn't it up to the Orbi system to beamform and send the appropriate packets to the device to/from the nearest satellite? No. Orbi provides the platform for devices to connect to.
https://en.wikipedia.org/wiki/Beamforming
What happens if you turn OFF the RBS?
