alokeprasad
Apr 16, 2021Mentor
How to tell which satellite a device is connected to? How to make it switch satellites?
Q1. How can I tell from the web interface which satellite a device is connected to? I can use the iOS app to do so, but it seems to be a glating oversight to not have this info be available via the ...
- Apr 16, 2021
Fast Roaming is IEEE standard 802.11r. https://en.wikipedia.org/wiki/IEEE_802.11r-2008
Notice in the first sentence, "for devices in motion". It is common for the network software in smartphone, tablets, and laptops to be set up to "roam" (either the 'old way' or 802.11r). Devices that do not move seem to be programmed to connect to an access point and stay connected until the access point signal goes away entirely.
A Ring battery camera is not likely to "roam" because it is physically moved to a new location.
As you have discovered, unless a device is programmed to look for better WiFi connections, there are only three methods that will get it to change:
- Power Cycle the device.
- Have the device "forget" the WiFi, search again, and reconnect. (which can be done on a television, but not on a security camera because once it disconnects it no longer accepts commands)
- Power Cycle the access point.
I doubt very much a complaint will get much traction at Ring. Generally, security cameras are placed somewhere and left there for extended periods of time.
Sorry if I missed the point of the discussion.
CrimpOn
Apr 16, 2021Guru - Experienced User
alokeprasad
Apr 17, 2021Mentor
Makes sense. A security camera is not designed to switch access points at it is supposed to be installed at a fixed location.
That explains why the camera would doggedly stay connected to a satellite, with very poor signal strength (RSSI measured by the cam) even though I had brought it a few feet from the RBR.
Summary: When moving the Ring (or any security cam) to a new location, power-cycle the cam.
