ketchumr
Feb 20, 2018Guide
how to turn of 5GHX radio on the Orbi router
I am looking to turn off the 5ghz on the Orbi RBR50 and RBS50, is there a way to do this? I have some in home automation devices that can only use 2.4ghz singal and I need to be able to turn off the ...
michaelkenward
Feb 21, 2018Guru - Experienced User
You might get better answers if you put your questions in the appropriate section of this user-to-user self-support forum:
