Fergus47's avatar
Fergus47
how to turn off 5ghz on Orbi RBK50 to connect a device
I have been searching and searching and then searching for a solution to the problem of turning off the 5ghz on the Orbi.  I have tried (several times) the solution that is often suggested of logging in and turning off the SSID broadcast but it doesnt work for me and still does it!  The problem I have is a device call Smartap which is an evalve that controls my bath and shower.  There was an issue 2 weeks ago and I need to reattach it to use it properly, the problem is it only works if there is NO 5ghz signal.  I dont have any support for the Smartap as the company was sold during lockdown and there is not anyone available for support.  It is causing me huge problems.
  • FURRYe38's avatar
    Netgear provides a simple mechanism to accomplish this. The Orbi RBR50 has a feature which many users have found allows them to set up devices which require the smartphone to be attached to WiFi at 2.4G:
    Connect a device with a large screen to the Orbi web interface, http://orbilogin.net
    (computer, laptop, tablet)
    The user name is "admin" and the password is the web interface password, not the Orbi 'app' password.
    Navigate to the Advanced Tab, Advanced Settings (at the bottom), Wireless Settings.
    On the Advanced Wireless Settings page, uncheck the box under Advanced 5G Settings that reads
    Enable SSID Broadcast
    Click Apply
    The router will go through a cycle which takes foreeeeeeeever.
    On the smart phone, go into Network settings.
    "Forget" the Orbi WiFi.
    Search for available WiFi systems.
    Select the Orbi WiFi
    Enter the password and Connect
    The smartphone is now connected to the Orbi at 2.4G
    Note that if you attempt to "double check" by opening the Orbi Attached Devices page, that page takes several minutes to update.
    Just go with it.
    Open the device smartphone app and go through the setup process.
    After the device is connected and working, undo the process.
    On the web interface, check the box and click Apply
    On the smartphone, Forget the Orbi, find it again, and connect again.
    This takes less time to do than to read. It has worked for me several times.
    Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
    • Fergus47's avatar
      Fergus47
      Spoiler
      Thank you for this, yes unfortunately I have tried this ☹️
  • CrimpOn's avatar
    CrimpOn
    I'm wondering how the Smartap device was set up the first time?
