Choclit
Feb 03, 2020Aspirant
How to turn off firewall on Orbi
I am trying to connect a Lutron Radio RA2 repeater to my network and the aoft3are is not finding it even though it is plugged in to my main Orbi router. It has been suggested that I turn off the fir...
Feb 03, 2020Guru - Experienced User
Try putting the IP address this one device gets into the DMZ on the RBR...
Is this device a wired or wireless connecting device?
The Firewall is automatic and can't be disabled. You could configure ports thru the firewall as needed. You'll need to contact the Mfr of this device to see what ports they use.
