Choclit
Feb 03, 2020Aspirant
How to turn off firewall on Orbi
I am trying to connect a Lutron Radio RA2 repeater to my network and the aoft3are is not finding it even though it is plugged in to my main Orbi router. It has been suggested that I turn off the fir...
Choclit
I just looked at attached devices and the repeater is correctly recognized as being directly attached. I think I will fire up the Windows computer tomorrow and try that as the next step.
eljarviso
Feb 03, 2020Luminary
How do you have your network configured on your parallels VM? You should be using a bridged network. Additionally ensure that both your Mac and your Windows VM do not have their firewalls turned on. Additionally if you are bridging a wireless connection on your mac it might be blocking broadcast/multicast packets. This MIGHT be resolved by using a USB ethernet adapter and conencting it directly to the VM using USB sharing.
