texandriver
Apr 06, 2019Tutor
How to turn off SSID brocast on RBR50 ORBI?
All- I logged into orbi as admin via web. There doesn't seem to be an option on my main network to turn off SSID BROCAST, it does however let me turn it off on my guest network. Could someone post st...
- Apr 22, 2019
Let us know how it goes. :smileywink:
texandriver wrote:
I'll check to see if this works in a couple weeks when I return. Thanks.
Apr 07, 2019Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings. You can uncheck the broadcast SSID check box for each frequency.
- texandriverApr 21, 2019TutorI'll check to see if this works in a couple weeks when I return. Thanks.
- FURRYe38Apr 22, 2019Guru - Experienced User
texandriver wrote:
I'll check to see if this works in a couple weeks when I return. Thanks.- texandriverMay 21, 2019TutorFixed Thank you Furrye38
