icalks
May 10, 2019Tutor
How to turn off the 2.4GHz channel on the Orbi RBR50?
In advanced settings I tried setting the 2.4GHz channel from "auto" to 1, CTS/RTS to 1, Preamble to "short" and Transmit Power to 25%. Also disabled SSID broadcast, disabled 20/40 coexistence, and dis...
icalks
May 13, 2019Tutor
Thanks for the link, however, that process is unecessarily complicated. Disabling the 2.4GHz or 5GHz channel should be as easy as going into wifi settings and checking/unchecking a box. This seems like an interface shortcoming that Netgear/Orbi should address with an update.
May 13, 2019Guru - Experienced User
You can disable the WiFi SSID broadcast only. Disabling of either radio is not officially supported by any other means. This is not a bug.
