dp118
Dec 06, 2018Aspirant
How to turn off WiFi radios on CBR40
How do I turn off one or both of the WiFi radios? I want to temporily use this as a cable modem without wifi to test wifi routers attached to it using the same SSID so I don't have to change setting...
- Dec 06, 2018
Currently there isn't any way to turn OFF the wifi radios on the Orbi systems and leaving the router section running.
There is Bridge mode on the CBR40 which would effectivaly turn OFF the radios, however this also disables the router portion of the CBR40, thus making it a modem only unit. I use this when i'm testing external routers.
Orbi's are the one MESH product that doesnt' allow for disabling of wifi radios. Others have asked NG for this feature. Will see if they will allow it at some point. For now, use Bridge mode on the CBR40.
dp118
Dec 07, 2018Aspirant
Thanks. Exactly the information I need. When in bridge mode are the LAN output ports on the Orbi disabled?
Dec 07, 2018Guru - Experienced User
Ya know I didn't check that. I just plugged in the cable to the yellow port in back when in bridge mode. I presume the other ports are disabled when in bridge mode.
- dp118Dec 09, 2018Aspirant
My CBR40 has no yellow WAN port, only 4 LAN ports. But I'll give it a try through one of the LAN ports to see if I can disable radios and also get an active LAN port to test other routers. Thanks again.
- FURRYe38Dec 09, 2018Guru - Experienced User
Once you enable bridge mode on the CBR40, the wifi willl be disabled.
I just checked mine, It's in brige mode. The 4 LAN ports in back are disabled and do not work. Only the Yellow WAN port works in bridge mode. :smileywink:
