felho
Mar 15, 2023Tutor
How to ugrade an RBS50 if it is not connected to the router?
Hi,
I have an RBR50 and RBS50. For some reason, the satellite can't connect to the router.
I tried to do a factory reset on both devices; I went through the setup process driven by the mobile application. But still, the satellite can't connect. After the sync process, it shows blue but doesn't connect to the router.
I thought one option could be a firmware upgrade on it, but I don't know how to do it without the app. Is this possible?
TIA!
Take care,
Felhő
How do you know its not syncing?
Usually if the satellite is blue, it sync'd.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
- felhoTutor
Thank you very much for the prompt answer. The mobile app shows that zero satellite is connected to the router. Also, in the area where the satellite is, the wifi is very weak versus being close to the router. As an experiment, I moved the satellite next to the router, but they didn't connect even in that setup.
Try logging in through browser and checking its connection.
I'm not very trustful of the app and when it has a blue light, it usually means it sync'd successfully.
