kevincol's avatar
Feb 21, 2017
How to update my DNS entries in Orbi?
I'm trying to force Google SafeSearch on at the router / Orbi level.  I can't find any entries on the admin page to set the DNS entry for www.google.com to be a CNAME for forcesafesearch.google.com.
Does the Orbi support this?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Kevincol
    The DNS server would be on the Internet Setup page.
    DarrenM
    • kevincol's avatar
      kevincol
      Tutor
      Hi Darren,
      I can see where you can put in a DNS server on the Internet Setup Page.  That isn't what I was trying to accomplish.  I need to input a CName and all that is available is an IP address.
      • MarkC1024's avatar
        MarkC1024
        Luminary
        How is that supposed to happen?  Doesn't it need DNS to look up the IP for the name you're entering?  Try using 216.239.38.120.
