crazyh
May 29, 2020Tutor
How to Upgrade from Version V2.1.4.16_1.1.31 - Orbi RBR50 ISP Provided
Hello All, I have gone through few posts in forum to update my curret orbi RBR50 device that is running version V2.1.4.16_1.1.31 to the netgear latest FW. Orbi Device is provided by ISP and they a...
- Jun 01, 2020
Try this method, this differs abit from the other link I included:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked. However I don't have a ISP Orbi. Mines NG stock.
crazyh wrote:Is there any way like Jaibreak/Root the ISP lock to load the stock NG FW.
As far as this is NG device so i think there would be some way to load stock FW. Can the NG support team will help...??
May 31, 2020Guru - Experienced User
If you tried the TFTP method and it doesn't work, then the system is locked by the ISP and probably can't be changed.
- crazyhMay 31, 2020Tutor
- tomschmidtMay 31, 2020Virtuoso
Do you own or rent this Orbi from your ISP? If it is rented, then the FW is what they are supporting and you should only work with your ISP for support of it. If you purchased it from your ISP, then contact your them to request they unlock it so that you can update the firmware.
- crazyhJun 05, 2020Tutor
I have purchased this from ISP, they will not unlock it or release new FW.
- FURRYe38Jun 01, 2020Guru - Experienced User
Thank you bro... It work's.
What i did is like, Power off the orbi router and press the reset with a sim ejector and turn on the orbi and count for 10 flashing then release the reset and hit enter to windows machine for tftp.
