utut7
Aug 24, 2020Aspirant
how to use Orbi RBK23 with 110v only in 240v countries
Hi all, i bought the Orbi RBK23 end of April and just opened it yesterday (just arrived home from a long travel). the intention was to use it outside USA but unfortunately the AC/DC adapter is not d...
- Aug 24, 2020
utut7 wrote:Can i use a local AC/DC adapter with 240V and ouput of 12V, 2A?
Would it harm the router and sattelites?
What to look for when purchasing a local adapter if it works?
There have been numerous posts indicating that Orbi power supply is a "universal" model and works fine in countries with higher voltage with a converter plug. It certainly would not hurt to plug it in and use a voltage meter to measure the output voltage. If it measures 12v, you should be "good to go."
More amps is never a problem. The device will draw only as much as it needs. Not enough amps will not work.
The KEY item is the actual plug dimensions that have to match. Some universal power supplies come with an assortment of tips.
Mstrbig
Aug 24, 2020Master
If you do not already have one you could pick up a power travel adapter and that will solve your problem. There are many to choose from, pretty inexpensive and probaly cheaper than a 240V power supply.
