utut7
Aug 24, 2020Aspirant
how to use Orbi RBK23 with 110v only in 240v countries
Hi all, i bought the Orbi RBK23 end of April and just opened it yesterday (just arrived home from a long travel). the intention was to use it outside USA but unfortunately the AC/DC adapter is not d...
- Aug 24, 2020
utut7 wrote:Can i use a local AC/DC adapter with 240V and ouput of 12V, 2A?
Would it harm the router and sattelites?
What to look for when purchasing a local adapter if it works?
There have been numerous posts indicating that Orbi power supply is a "universal" model and works fine in countries with higher voltage with a converter plug. It certainly would not hurt to plug it in and use a voltage meter to measure the output voltage. If it measures 12v, you should be "good to go."
More amps is never a problem. The device will draw only as much as it needs. Not enough amps will not work.
The KEY item is the actual plug dimensions that have to match. Some universal power supplies come with an assortment of tips.
CrimpOn
Aug 24, 2020Guru - Experienced User
utut7
Aug 25, 2020Aspirant
Agree with you. It is labelled as 110V but actually it is universal. I plugged it in and used an old router i had with same output rating and worked fine. No explosion. Thanks
- jonathanlakeJul 13, 2022Aspirant
My power supply burnt out and the orbi was outputting slow speeds.
I'm using a 110 240 converter until I get a new supply 12 240.
I'll let you guys know how it works out.
